Date/Time: Fri, 18 Apr 2025 06:40:12 +0000
MaximumPositionAllowed=1 Where are you hiding this setting now?
View Count: 96
[2025-03-24 02:03:16] |
DHTrading - Posts: 22 |
"Using Sierra Chart version 2747 (March 2025). Cannot place automated orders for more than 1 contract; Trade Service Log shows 'Max. Position allowed: 1'. Cannot find 'Maximum Position Quantity for Automated Trading' in Trade > Global Settings. Where is this setting located?"
[2025-03-24 02:05:53] |
2025-03-23 21:05:19.587 | Auto-trade: Replay 5.00X: NQM25-CME [C][M] 10.00 Range #3 | Trade Signal Reader | SellEntry | Bar start date-time: 2025-02-26 05:20:55.110 | SellEntry signal is ignored because maximum Short Position quantity allowed has been reached or would be exceeded with new order. Max. Position allowed: 1. Resulting Position without working orders: -2. Resulting Position with all working orders except exits: -2. Resulting Position with Market working orders: -2. Current Position: 0 I've looked all over. Cannot find where to change this from 1 to something higher. |
[2025-03-24 03:16:28] |
Sierra_Chart Engineering - Posts: 19259 |
Is this a Spreadsheet trading system or written using ACSIL?
[2025-03-24 04:42:29] |
It is ACSIL
[2025-03-24 04:46:59] |
I'm a bonehead. It was a PEBKAC ID10T error: if (sc.SetDefaults)
{ sc.GraphName = "Trade Signal Reader"; sc.AutoLoop = 1; sc.FreeDLL = 0; sc.MaximumPositionAllowed = 25; I thought I put it in but apparently after review noticed I had forgotten to set it. Date Time Of Last Edit: 2025-03-24 04:48:32
[2025-03-24 05:18:56] |
OK good that you found this. Here is the relevant documentation: Automated Trading Management: MaximumPositionAllowed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-03-24 07:09:57] |
I went through that a couple of times and couldn't get both brain cells to fire in the same direction. It's all squared away and working nicely now. Thank you for taking the time.
