Date/Time: Sat, 12 Sep 2026 18:56:01 +0000
Trading System Based on Alert Condition - Suggestion
View Count: 674
| [2025-03-23 16:42:38] |
| User316362 - Posts: 215 |
When "Allow Trading only during time Range is Set to yes and the time interval is defined. The Study behaves fine for trading but still shows the alert outside of this range (even though it doesn't trade which is proper). My suggestion is for the visible alert not to show outside of the set time range or add another setting like "Allow Alerts on during time Range" to the study. It's important if referencing the actual alert from other studies. Thanks for considering. |
| [2025-03-24 08:22:46] |
| Sierra_Chart Engineering - Posts: 24844 |
You will need to modify the study to do this. Refer to: How to Build an Advanced Custom Study from Source Code This is not a change that we would ever make ourselves. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-03-24 08:22:54
