Date/Time: Fri, 20 Sep 2024 07:05:56 +0000
chart tab font size
View Count: 1844
[2014-09-25 13:17:53] |
User021827 - Posts: 174 |
hi Within a chartbook, an I change the size of the font on the chart tabs ? I have to scroll the tabs left or right if I have a few charts open. I was hoping to change the font size or what the tab says in order to fit the tabs without having to scroll. see attached photo of tabs thanks Shane |
chart tabs.png / V - Attached On 2014-09-25 13:17:27 UTC - Size: 17 KB - 350 views |
[2014-09-25 14:18:17] |
tobi - Posts: 351 |
you can rename them either by - right-click on the tab and choose "rename" from the menu that comes up or - Chart >> Chart Settings >> Advanced Settings 2 and type in "Title Bar Name" the name you want to use and check "Use Title Bar Name As Tab Label" mine look like this ... |
[2014-09-25 15:07:06] |
Hi great ! , thanks for that info ! perfect regards shane |
