Date/Time: Tue, 25 Mar 2025 21:37:27 +0000
vertical and horizontal lines
View Count: 67
[2025-03-23 15:36:41]
natanibz - Posts: 140
Hello, is it possible to set vertical lines every given period of time (for example every 30 minutes) and horizontal lines every certain number of points (for example every 50 points) throughout the chart ? Thanks
[2025-03-24 01:12:50]
User303857 - Posts: 123
You need to use the Horizontal Grid:
Chart Menu: Horizontal Grid (Chart menu)
Horizontal Grid Line Increment (Scale Settings)
[Link] - [Top]
The Horizontal Grid Line Increment displays and sets the increment between Horizontal Grid lines in the chart region of the main price graph or study that you are modifying the Scale Settings for.
Use the Time Line study:
Time Line
[2025-03-24 15:49:30]
John - SC Support - Posts: 38945
There is also the Vertical Grid. Refer to the following:
Chart Settings: Show Vertical Grid (Chart >> Chart Settings >> Grid >> Show Vertical Grid menu)
