Date/Time: Tue, 25 Mar 2025 21:34:28 +0000
[Programming Help] - Question about Fast Changing by Keyboard
View Count: 102
[2025-03-23 04:09:57]
Tony - Posts: 563
I am using same time frame for all my charts, sometimes I press number+enter accidentally, and the chart would switch to a time frame I don't want and I have to go to the Chart Setting window to change it back.
Couple of questions:
I am wondering if this feature can be disabled? Similar to setting "Support Symbol Entry from Chart Window" to "No". If not:
I understand that I am able to clear the keyboard buffer by pressing "Esc" key, I am wondering if this buffer can be cleared with ACSIL?
Thanks so much!
Date Time Of Last Edit: 2025-03-23 18:57:39
