Date/Time: Tue, 25 Mar 2025 21:34:29 +0000
Ask/Bid Ratio
View Count: 50
[2025-03-22 20:33:03] |
cmack1011 - Posts: 88 |
IS there a way to see the ratio of Ask/Bid volume in the Numbers Bars Calculated Values study? I looked in both set 1 and 2, but did not see a way to display this ratio of these two numbers. Thx Also, is there still access to the custom study "ECIVwapAnchorV1.5." ? I cannot find it under this menu. Thx Date Time Of Last Edit: 2025-03-24 13:07:07
[2025-03-24 15:28:31] |
John - SC Support - Posts: 38944 |
The Ask/Bid ratio is not available directly in the Numbers Bars Calculated Values study. But you can create this using the "Study Subgraphs Divide/Ratio" study and using the Ask Volume Total and Bid Volume Total values from the Numbers Bars Calculated Values study and then displaying that result using the "Numeric Information Reference" study. Refer to the following: Study Subgraphs Divide/Ratio Numeric Information Reference For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
