Date/Time: Fri, 18 Apr 2025 06:37:46 +0000
Using the Max Open Proit Value
View Count: 106
[2025-03-22 19:08:09] |
Fikklish - Posts: 5 |
Is there a way that I can get that max open profit per position into the spreadsheet? The Trading Profit/Loss Text study has this value, but it has no subgraphs from which it can then be used elsewhere.
[2025-03-24 23:36:21] |
John - SC Support - Posts: 39353 |
There is not a way to do this with the existing studies. You could modify the "Trading Profit/Loss" to store the information in a subgraph to make it available, or create your own study. Refer to the following: How to Build an Advanced Custom Study from Source Code For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
