Date/Time: Fri, 18 Apr 2025 06:42:35 +0000
Zig Zag study quick change of input value
View Count: 102
[2025-03-22 18:11:18]
User273916 - Posts: 7
I love the Zig Zag study, but due to rapidly changing volume and volatility I find I'm constantly going into the settings to change the "reversal %" input to get the waves the size I want.
Is there any way to add buttons to the chart or the control bar to change that specific input? Buttons for "+0.01" and "-0.01" would be ideal. Or are there any other options to quickly change the input value?
[2025-03-24 15:04:13]
John - SC Support - Posts: 39353
Refer to the following for an option on how to change inputs:
Chart Studies: Changing Study Inputs Directly from Chart
Otherwise, you would have to create a custom study to do what you are wanting. Refer to the following:
ACSIL Interface Members - Functions: sc.SetChartStudyInputFloat()
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php
