Date/Time: Thu, 27 Mar 2025 01:40:54 +0000
Trade Eurex and CME products using just one installation
View Count: 123
[2025-03-22 16:00:42] |
User581836 - Posts: 6 |
Is it possible to trade Eurex and CME products without running 2 installations of sierra chart? I followed the instructions in regards to setting up another installation specifically for a CQG account to access Eurex and to keep the first one for CME only. However, this does not meet my needs. Ideally I need to have my Eurex and CME DOMS on the same screen and the same for my charts e.g ZN and FGBL charts. Is it not possible to access both my CME and Eurex data from my CQG account? Thanks in advance |
[2025-03-23 07:55:11] |
User849792 - Posts: 1 |
If you use only one routing service (CQG), then only one installation would be needed. Two installations are required when using CME Teton and Eurex CQG routing. That's also my current setup and I have CME and Eurex charts on the same screen. Simply detach all the charts (Window - Detach Chart Window) and arrange them the way you want. On any detached chart you can also use "Window - Tile ..." to arrange the charts automatically. |
[2025-03-25 22:19:39] |
Sierra_Chart Engineering - Posts: 18960 |
You can use CQG to trade both CME and EUREX. Have your broker set that up. Market data for CME and EUREX needs to come from the Sierra Chart Denali Data Feed.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-03-25 22:20:22
