Date/Time: Fri, 18 Apr 2025 06:23:45 +0000
Web API: Adding New DLLs
View Count: 151
[2025-03-22 04:30:15] |
Gradient - Posts: 120 |
Hi, Is it possible to use the Web API to add new DLLs in addition to new users? For example, given a list of DLLs to add to the distribution list, can the web API be used to programmatically add each element instead of using the GUI interface. Thanks |
[2025-03-25 17:25:51] |
Sierra_Chart Engineering - Posts: 19259 |
We are checking on this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-03-25 17:25:56
[2025-03-25 17:33:40] |
We looked this over and this is something that is not planned to be supported.
[2025-03-25 17:41:34] |
Ok Thanks
