Date/Time: Wed, 26 Mar 2025 21:22:36 +0000
replay gets stuck at 16:59:59 with multiple charts
View Count: 62
[2025-03-21 19:48:52]
MR.WAGLER - Posts: 2
Hi, I am new to sierra charts, I am trying to replay multiple charts using the accurate trading system back test mode with processing steps set to 0.01. It was working fine a few days ago but now it gets constantly stuck at 16:59:59 during any date or time. I can replay all charts starting at 09:30:00 but will always freeze at 16:59:59. It wont get stuck if I only replay a single chart, but will get stuck if I am replaying more then one chart. This also happens on the calculate at every tick/trade. I have changed the processing steps to higher numbers but it will always get stuck at 16:59:59.
[2025-03-21 19:56:22]
Sierra_Chart Engineering - Posts: 18960
This happens because there is no trading for a period of time after that time. When that time is encountered increase the replay speed to 120 and weight about 30 seconds and then it will resume. After that reduce the speed to what you had it at previously.
[2025-03-22 18:46:18]
Hi, thank you for responding so fast, I know there is no trading during that period. I have tried the jump method, upped the speed and waited and it will not resume onto the start of the 18:00:00 session no matter how long I wait. When I am replaying a single chart it works fine and was working fine a few days ago when I was using multiple charts, but now it gets stuck at 16:59:59 when replaying multiple charts (works fine on a single chart replay). The session settings and data limiting are all matched on the charts so I am not too sure why it won't properly move forward.
Date Time Of Last Edit: 2025-03-22 18:46:54
[2025-03-22 20:12:45]
We just ran a test of two charts. The Replay Mode was Accurate Trading System Back Test Mode. Processing Step in Seconds was 60 seconds.
The replay speed was 120 times. When we got to 16:59:59 there was a pause as expected and in about 30 seconds the replay resumed at 18:00:00. No issue.
Test again. You should not have any trouble with this.
Date Time Of Last Edit: 2025-03-22 20:12:58
