Date/Time: Sat, 19 Apr 2025 09:48:46 +0000
Alerts playing for 5-10 mins at startup of workspace
View Count: 97
[2025-03-21 18:32:13] |
TopGunTrader - Posts: 191 |
Hi, I recently have a problem I hear the same alerts 50-250 times often multiple ones 50-250 times each for 5-10 mins when I start my workspace. It's driving me nuts especially since I trade mornings and afternoons and close Sierra down so have to hear them twice a day. I've included the workspace but I never used to have this issue with much older versions of Sierra and had many alerts then as well. Any ideas if its my fault on how to fix the color bar alerts? |
[2025-03-21 21:03:20] |
John - SC Support - Posts: 39362 |
When we open your Chartbook we get 5 alerts. We are not getting the multiple alerts as you are stating. When this occurs to you, you need to look at the Alert Manager and see what it is showing for alerts. If the alerts are all in there, then you will have to determine what to do about them and how they are occurring when the chart is opened. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
