Date/Time: Fri, 22 Nov 2024 07:34:51 +0000
FootPrint chart showing candlestick-How do I only show foorprint
View Count: 2484
[2013-05-10 16:01:42] |
User57124 - Posts: 48 |
somewhere I changed my settings and now the candlesticks are overlaid behind footprint pattern, Where do i change this so the footprint numbers is all that shows thx in advance R |
[2013-05-10 19:27:12] |
Please let us know what studies you have on the chart? At what Sierra Chart version you are running. For now just add the Numbers Bars V2 study to the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
