Date/Time: Sat, 19 Apr 2025 09:46:40 +0000
Orderflow chart for furtures ES!
View Count: 125
[2025-03-21 18:00:59]
User540358 - Posts: 4
Good morning,
where is the orderflow chart for ES1, I've tried looking into the Sierra chart app to see.
[2025-03-21 20:58:15]
John - SC Support - Posts: 39362
To begin with, you are on a trial and have limited data you have access to. In particular, you do not have access to data for the E-Mini S&P 500 Index Futures from the CME Group (ES). Refer to the following for what data you have available:
Sierra Chart Trial Account
To get an Order Flow chart you need to add the Numbers Bars study. Refer to the following for how to add a study:
Chart Studies: Adding/Modifying Chart Studies
And refer to the following for the Numbers Bars study in particular:
Numbers Bars
