Date/Time: Sat, 19 Apr 2025 09:46:40 +0000
footprint histogramme
View Count: 57
[2025-03-21 17:24:16] |
User757683 - Posts: 1 |
bonjour, pourriez vous me dire comment configurer le footprint comme sur la capture d écran jointe . Merci
[2025-03-21 17:30:11] |
John - SC Support - Posts: 39362 |
From Google Translate: Hello, could you tell me how to configure the footprint as in the attached screenshot. Thank you.
Set the "Column 1 Numbers Bars Text" is set to "None". And it looks like the "Column 1 Background Type" is set to "Ask Bid Volume Split Profile". But we can not say exactly what "Column 1 Background Coloring" is set to. Most likely it is "Based on Dominant Side AskVol BidVol Percentage. But there are others that it could be. You would need to determine what you want to see and use the appropriate background coloring for that. The documentation for the Numbers Bars is at the following link: Numbers Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
