Date/Time: Tue, 15 Apr 2025 14:29:11 +0000
Resetting Internal Order ID's
View Count: 130
[2025-03-21 14:51:26]
kam2001 - Posts: 86
Hi, Everytime I place an order the internal order ID is incremented and to find an existing order i am doing a for loop in my code. Is it possible to reset the internal order ID at start of each day or once it reached to certain number so that it starts again from number 1, which will help me to avoid keep changing max value (2000)in for loop. Thanks
for(int i = 0; i < 2000; i++) {
sc.GetOrderByOrderID(i, ExistingOrder)
[2025-03-21 21:55:21]
Sierra_Chart Engineering - Posts: 19226
No there is no possibility of this.
[2025-04-05 08:11:03]
kam2001 - Posts: 86
Thanks for the response, so if it is not possible than in that case, Is there a function that could get me the Internal ID of the very recent order, may it be a working, opened, filled or even cancelled order without looping(iterating) ?
Date Time Of Last Edit: 2025-04-05 08:12:33
[2025-04-08 01:28:25]
ForgivingComputers.com - Posts: 1040
Is there a function that could get me the Internal ID of the very recent order, may it be a working, opened, filled or even cancelled order without looping(iterating)]?
Each chart has a list of trades. Use
sc.GetTradeListSize
to get the size of the list, then loop through the list using
sc.GetTradeListEntry
Automated Trading From an Advanced Custom Study: sc.GetTradeListEntry()
