Date/Time: Fri, 20 Sep 2024 06:22:28 +0000
Symbols updating
View Count: 945
[2014-09-25 12:10:03] |
joshtrader - Posts: 485 |
After loading a chartbook, there were some messages that certain symbols would be marked for real-time updates. However, those symbols are not in any charts in the chartbook, and they are not in the intraday update file list. Is it possible they are listed somewhere else?
[2014-09-25 16:40:53] |
They could be on a Quote Board or you could have a Symbol Alert set up for them.
[2014-09-25 18:07:14] |
They were in symbol alerts, that was it, thanks.
