Date/Time: Sat, 19 Apr 2025 09:42:44 +0000
Firt in firt out not working
View Count: 100
[2025-03-20 20:49:26] |
User561779 - Posts: 2 |
ciao ho un problema con gli scale,first in first out,ho lo scale out attivo,e l'impostazione di fifo attiva,pero' non mi scala mai il primo contratto aperto,scala sempre il contratto piu' esperto,cosa posso fare? nelle immagini riporto degli esempi, ex 1 il primo contratto aperto e' sul poc (linea rossa tratteggiata) scalo per chiudere quel contratto ma scala il contratto o tp piu' esterno, ex2 il primo contratto apperto e' sulla 2 deviazione standar,scalo e lo chiude,per qualche motivo chiude sempre il contratto con il tp piu' esterno,come risolvere questo problema? grazie mille
[2025-03-20 21:07:31] |
John - SC Support - Posts: 39362 |
From Google Translate: hi i have a problem with the scales, first in first out, i have the scale out active, and the fifo setting active, but it never scales the first open contract, it always scales the most experienced contract, what can i do? in the images i report some examples, ex 1 the first open contract is on the poc (red dotted line) i scale to close that contract but it scales the most external contract or tp, ex2 the first open contract is on the 2nd standard deviation, i scale and close it, for some reason it always closes the contract with the most external tp, how to solve this problem? thank you very much
When using the "Scale In/Out" options, the control for which order gets scaled is controlled by the following setting and the one below it: Global Trade Settings Windows: Scale In (Global Settings >> General Trade Settings >> Scale In/Out) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
