Date/Time: Sat, 19 Apr 2025 09:45:10 +0000
EMA200 changes price on 1hour timeframe depending on days to load - but enough days
View Count: 94
[2025-03-20 13:56:53]
MMM1238 - Posts: 20
Hi, I just noticed an issue. Please look at the most left and most right chart at the top in my screenshot. These are both 1 hour charts. The left has 20 days to load and the right one 40 days to load.
The pink EMA200 looks different from each other, but there is enough days
left: 20 days means 480 bars - EMA 200 should be fine
right 40 days 960 bars
Why do they look different?
Many thanks for your help.
Date Time Of Last Edit: 2025-03-20 13:57:18
imageEMA 200 pink are different depending on days to load.png / V - Attached On 2025-03-20 13:57:14 UTC - Size: 348.4 KB - 26 views
[2025-03-20 14:24:33]
John - SC Support - Posts: 39362
Is the EMA200 based on the same Input for both charts?
[2025-03-20 15:02:03]
MMM1238 - Posts: 20
yes it is. Then I adjusted the left chart also tto 40 days and only then EMA looked the same.
[2025-03-20 15:07:45]
Sierra_Chart Engineering - Posts: 19276
This is documented here:
Moving Average - Exponential
