Date/Time: Tue, 25 Mar 2025 22:07:52 +0000
Run Program When This Alert Triggered: cmd.exe disrupts windows
View Count: 125
[2025-03-20 00:22:01]
virtualcointrading - Posts: 43
whenever a program is run on an alert trigger, the cmd.exe prompt SC launches shifts the focus, i.e. if a full screen application is launched the command prompt will reduce it, if I'm typing something characters that I type when the alert was triggered will miss because cmd.exe was in focus, etc...
Is there a way for "Run Program When This Alert Triggered" to quietly execute the specified program?
Regards,
[2025-03-20 01:52:53]
user_xyz - Posts: 459
Interesting I briefly looked into solving this issue this past weekend and got side tracked. Often I'm typing on a screen overlay and when the alert gets triggered all my text / work disappears
[2025-03-20 06:54:59]
Sierra_Chart Engineering - Posts: 18944
We see why this issue occurs. We will solve this. But this will still happen if you are running an operating system batch file. It cannot be avoided to open the command window when running a batch file.
[2025-03-20 08:26:22]
In my case I'm running a Python script.
[2025-03-22 15:38:14]
SC could you make a note here when / what version you solve this so we can test out. Thanks
[2025-03-22 16:29:35]
Update to version 2748. The issue should be resolved as long as you are not running an operating system batch file.
[2025-03-23 15:22:09]
I just ran through a few tests in replay mode. Prior I would see the cmd.exe flash and then my python script would launch. Alert is triggering as expected but external program doesn't appear to get called.
"C:/.../python.exe" "C:/.../alerts.py"
[2025-03-24 08:21:59]
Check the Message Log for errors:
Message Log
[2025-03-24 10:00:32]
Sorry missed error code earlier in log.
Error creating process "C:/.../python.exe" "C:/...alerts.py" Windows error code 87: The parameter is incorrect.
Also in case it wasn't clear in SC in Run Program when this Alert Triggered field I have "C:/.../python.exe" "C:/...alerts.py"
Would think other user similar since both of us running python scripts.
Date Time Of Last Edit: 2025-03-24 12:54:44
[2025-03-25 17:20:38]
With the changes which support a direct call to CreateProcess, do not use any quote marks.
And for now parameters are not supported. You can only specify the executable path and filename.
