Date/Time: Sat, 19 Apr 2025 09:51:15 +0000
ntfy notification app - issues with screenshots
View Count: 139
[2025-03-19 17:11:17] |
mattvk - Posts: 34 |
I have successfully gotten my notifications working with the Sierra Chat Chat window sending order fill alerts via the ntfy app. However, it's also sending a link to the screenshot of the chart along with the order as a separate message. This worked fine in Telegram, as the photo displayed and the link was clickable to view a full-resolution version. With the Ntfy app, the link is not clickable OR even able to copy the URL text via the system copy/paste (on iOS). Additionally, it seems the option to send the screenshot (or not) has been removed from the chat settings, so now I can't disable it. How can I disable the screenshot option now? |
[2025-03-20 08:55:52] |
Sierra_Chart Engineering - Posts: 19276 |
We are using the Android version of the ntfy app. We see a link in the notification message, and it is clickable and goes to a browser. There is no issue with this. The options to capture a chart image are here: General Settings Window: Capture Chart Image on Alert for Chart (Global Settings >> General Settings >> Alerts >> Alert Settings) You can also view the images in the web-based chat; Chat and Communications Platform: Web-Based/Mobile Chat Application They will display inline. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-03-20 08:56:27
[2025-03-20 20:13:49] |
cesium - Posts: 129 |
In ios ntfy, is there a way to make the link clickable? thank you |
[2025-03-20 20:47:56] |
This is not within our control. The ntfy app was a quick solution for us to support notifications.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-03-20 20:48:13
