Date/Time: Sat, 19 Apr 2025 09:46:42 +0000
HIGHLIGHT DOM IMBALANCE BETWEEN CURRENT TREADED BETWEEN BID AND ASK
View Count: 102
[2025-03-19 14:58:59]
rebeccaemme - Posts: 11
Hello guys I would like to know if its possibile to Highlight an imbalance which appear on the DOM between Current Traded BID/ Ask.
If its possible to highlight like an imbalance with a factor more then 3.5 point.
Example: there was an imbalance more then 3.5 because Treaded BID was 1303/192 Treaded ASK. How its possible to setup an HIGHLIGHT when there is an imbalance which a factor more then 3.5? Thank you so much
imageunnamed.jpg / V - Attached On 2025-03-19 14:56:47 UTC - Size: 452.48 KB - 28 views
[2025-03-19 16:07:36]
John - SC Support - Posts: 39362
There are no built-in tools to allow you to note when there is an imbalance in the Current Traded columns. The only way to do this would be with a custom study. Refer to the following:
ACSIL Interface Members - Functions: sc.GetCurrentTradedAskVolumeAtPrice()
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php
[2025-03-19 16:11:40]
Thank you!
