Date/Time: Sat, 19 Apr 2025 09:42:45 +0000
Volume by Price for select times each day WITHOUT changing date?
View Count: 82
[2025-03-19 12:38:10]
TopGunTrader - Posts: 191
I want to have a bunch of volume by price to see how price migrates and the volumes associated with move.
For example 18:00 to 2:00 then 2:00 to 5:00 and 5:00 to 9:30 and 9:30 16:15 RTH hours.
Is there a way to do this without using start date time to end date time as I often forget to go change these some days.
I'd also like to see RTH hours of previous day and day before. I use to mark levels and then typically hide the 2 day old one. Can I see RTH hours for day +1 and day +2?
I always fair to achieve this other than showing them on all the past bars I want them all on right so I can easily mark up trading levels.
I suspect this isn't possible but hope I'm wrong.
[2025-03-19 14:13:51]
John - SC Support - Posts: 39362
You can get the current day profiles for those times by using the "Volume Graph Period Type" of "One Period from Start Time to End Time". This allows you to set the times and not have to update the dates. Refer to the following:
Volume By Price Study: One Period from Start Time to End Time
In order to see profiles for the previous days, you would need to use the "Number of Periods Back to Reference" and set it to "1" and "2" for the particular days back you want. Refer to the following:
Volume By Price Study: Number Of Periods Back To Reference
[2025-03-20 13:22:34]
Appreciate it will save me so much time!
