Date/Time: Sat, 19 Apr 2025 09:46:41 +0000
Rithmic Data issue
View Count: 158
[2025-03-19 11:46:44] |
IlanH75 - Posts: 2 |
Hello, I cannot access data rithmic via sierra chart, the service list is empty when I choose rithmic in data trade service, even when I wait 5 seconds after validating. I Followed the EZ solution and I opened an account via stage5 using Teton data, I have access to live data with it but I would like to use my propfirm account via rihmic to be able to trade it. Do you have a solution for this? THANKS. |
[2025-03-19 13:22:54] |
User135243 - Posts: 66 |
Use Rithmic Direct and if you don't see all the servers, close it and restart it and the servers should be available (I had the same as I tried it first)
[2025-03-19 15:16:10] |
John - SC Support - Posts: 39362 |
Refer to steps 12 through 15 at the following link: Rithmic Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-03-19 16:48:03] |
All good it's working.
