Date/Time: Tue, 15 Apr 2025 14:27:27 +0000
Moving Average - Sine-Wave Weighted
View Count: 187
[2025-03-18 20:49:06] |
User411320 - Posts: 318 |
Why can't length be modified?
[2025-03-18 22:29:26] |
John - SC Support - Posts: 39275 |
Essentially the study is using a Length of 5, as it is averaging over a series of 5 bars for each period. Refer to the following: Moving Average - Sine-Wave Weighted For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-03-25 18:32:56] |
thanks
[2025-03-26 13:00:10] |
can I base it off of a simple moving average to change the length?
[2025-03-26 14:42:14] |
No. It is hard-coded to only look at 5 bars.
[2025-03-26 18:50:44] |
cmet - Posts: 687 |
Here's a version that's adjustable using the same logic.
[2025-03-27 14:10:13] |
thank you! I downloaded the file and put it in the data folder. Because it's a cpp file is there specific instructions?
[2025-03-27 21:23:24] |
cmet - Posts: 687 |
You have to compile cpp files using Analysis > Build Custom Study DLL DLL is also attached to this post. Goes in the data folder. Date Time Of Last Edit: 2025-03-27 21:23:47
[2025-04-01 15:14:17] |
thank you
