Date/Time: Sat, 19 Apr 2025 09:42:45 +0000
Load less data than 1 day.
View Count: 72
[2025-03-18 18:36:54]
Dennzisme - Posts: 13
I want to limit the number of bars loaded to improve processing speed, as I'm using a 200ms interval. However, I can't find an option to load less than one day (for example, just one hour). I’d appreciate any help with this.
[2025-03-18 20:36:36]
John - SC Support - Posts: 39362
There is no way to have a single moving hour of data (i.e. have only the current hour displayed). You can have a single hour of data, but it requires that you set the "Days to Load" to 1 day and then adjust the Session Times to the one hour you want. You would have to constantly update the Session Times to get just the current one hour - you could do this just be adjusting the Start Time and keeping the End Time far enough out.
You could create a custom study that would adjust the Start and End Times for your charts. Refer to the following:
ACSIL Interface Members - Variables and Arrays: sc.StartTime1
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php
