Date/Time: Sat, 19 Apr 2025 09:45:12 +0000
Show order on chart
View Count: 67
[2025-03-18 18:28:03] |
User731023 - Posts: 148 |
I have the chart and DOM set up to show ES and trade MES. Why does my order not show up on the chart? Please help. Thanks |
[2025-03-18 18:35:29] |
I just changed the chart to MES and left the DOM as shown above. It then does show up on the chart. So. The DOM is showing ES and trading MES. However I really wanted the chart to show ES as well. Any way to do that? |
[2025-03-18 22:05:32] |
John - SC Support - Posts: 39362 |
We are not quite understanding the setup. In general, you will see the orders and positions on charts that have the same symbol either as the Main Symbol or as the "Trade and Current Quote Symbol". So if you are trading the MES, then the MES needs to be either the "Symbol" or the "Trade and Current Quote Symbol" for a chart. If this is not working for you, then start by referring to the following: Chart Trading and the Chart DOM: Viewing Orders and Trade Position on the Chart / Trade DOM For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
