Date/Time: Sat, 19 Apr 2025 09:46:43 +0000
Footprint Chart
View Count: 178
[2025-03-18 16:51:55] |
VenoYoTiK - Posts: 19 |
Hello, in which Setting can I disable these rectangles & what do they Show me? https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=117568 Thank you very much :) |
[2025-03-18 17:29:36] |
John - SC Support - Posts: 39362 |
We do not know offhand, as there are too many possibilities. If you can get us that chart by following these instructions then we can look and see where those are coming from: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-03-19 13:00:13] |
Of course, here is the Chartbook: https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=117610
[2025-03-19 15:14:23] |
Those boxes are from the Input to the Numbers Bars Study for "Highlight NonZero Bid&Ask Volume at High/Low. Refer to the following: Numbers Bars: Highlight Nonzero Bid&Ask Volume at High/Low For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-03-20 13:21:43] |
Ok thank you very much!
