Date/Time: Sat, 19 Apr 2025 09:45:11 +0000
Bottom Tabs
View Count: 102
[2025-03-18 14:24:57] |
User841161 - Posts: 275 |
Why are my bottom tabs not showing up on chart. It seems like that this just starting happening occasionally, not sure what is going on. Seems like at times the tabs are at the bottom and at times they are not.
[2025-03-18 14:35:33] |
I closed done and reopened, now chartbooks have the bottom tabs appearing. Not sure why this happpens?
[2025-03-18 23:01:17] |
Sierra_Chart Engineering - Posts: 19276 |
These types of problems occur when the title bars of chart windows are hidden, or hidden automatically. So avoid doing that.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-03-18 23:01:35
