Date/Time: Mon, 15 Dec 2025 09:09:37 +0000
SierraChart study settings, subgraphs, circle hollow
View Count: 324
| [2025-03-18 13:25:09] |
| User14953 - Posts: 258 |
How to display a circle that uses a thicker line in study settings, subgraphs, circle hollow?
| [2025-03-18 17:12:39] |
| John - SC Support - Posts: 43443 |
You need to change the "Width/Size". Refer to the following: Chart Studies: Subgraphs Tab >> Line Width For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-03-18 23:47:13] |
The diameter but not the line thickness increases when the "Width/Size" value is increased in Study settings (Color Bar Based On Alert Condition) > Subgraphs tab for the "Circle Hollow Variable". v.2540 Date Time Of Last Edit: 2025-03-18 23:52:28
| [2025-03-19 13:47:36] |
There is not a way to change the thickness of the line that defines the hollow circle.
