Date/Time: Fri, 20 Sep 2024 06:59:53 +0000
custom study toolbar buttons
View Count: 1018
[2014-09-25 00:00:18] |
jivetrader - Posts: 408 |
hi, i would like to toggle a study on/off via a toolbar button. is it necessary to use programming i.e. "Advanced Custom Study ToolBar Buttons and Pointer Events" or is there a simpler way? i am not familiar with ACSIL.
[2014-09-25 00:16:49] |
Yes, something like this would have to be programmed. No other simpler way. But you can hide a study by right clicking along the Region Data Line in the Chart Region where the study is located and selecting the Hide command. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-25 00:17:06
