Date/Time: Sat, 19 Apr 2025 09:45:12 +0000
Own button
View Count: 59
[2025-03-18 10:09:47]
Tin43 - Posts: 141
I can create a shortcut in the Control bar 1 for Build Custom Studies DLL (Build DLL)
What i want to know if it is possible to create a new shortcut that it is not in the menu.
Route Example:
Analysis (this is in the menu)---> Build Custom Studies DLL (this one too) ---> Build (this one is not) ---> Build With Visual C++ -Debug (this one is the one i want) and this one "Remote Build Standard"
I spent a lot of time going through those buttons. Is there a way to integrate both of them to the control bar?
Even using ACSIL or whatsoever?
Thanks in advance.
[2025-03-18 15:34:05]
John - SC Support - Posts: 39362
If ACSIL has the option available, then it would be possible to create a Control Bar button for something that does not already exist. Although the chances of an item being available through ACSIL that is not already an option in the Control Bars is slim. Definitely, the item for "Build with Visual C++ - Debug" is not an option within ACSIL, so this cannot be done for this item.
