Date/Time: Sat, 19 Apr 2025 09:42:43 +0000
chart drawing disappeared overnight
View Count: 151
[2025-03-18 08:12:41]
ASTrader036 - Posts: 9
I had a lot of drawings on my chart that I was using for analysis and back-test purposes, but they seem to have disappeared overnight. They still show in writing in the 'manage drawings' tab but not on the chart. I've looked in 'global setting's and then 'graphics settings' to check the 'chart text' and everything seems in order. I have also checked to make sure they are not 'hidden'.
I can obviously re-draw them but will be time consuming. Can anyone offer any advice?
Many thanks
[2025-03-18 10:56:42]
User135243 - Posts: 66
I guess you have drawn on the March contract and the chart rolled to the June contract?
[2025-03-18 11:11:29]
Hey,
Thanks for the response. I did think that but it isn't time to roll over yet (MCL). I did try it though, and definitely isn't that.
Thanks though, much appreciated
[2025-03-18 12:49:10]
yes Crude Oil also rolled over from April (MCLJ25 or MCLJ5) to May (MCLK25 or MCLK5)
[2025-03-18 13:25:53]
Yes I know. I'm already on MCLK for May. I would have to roll over to June and it isn't time for that yet. Thanks again
[2025-03-18 13:52:05]
yep no need to roll to June, it just rolled yesterday to May
[2025-03-18 17:14:24]
John - SC Support - Posts: 39362
Refer to the following:
Chart Menu: Update Chart Drawings to Current Symbol (Chart menu)
