Date/Time: Wed, 16 Sep 2026 04:02:48 +0000
VIX index data delayed
View Count: 4266
[2025-03-18 06:47:44]
epinay197 - Posts: 56
Hi I have paid for CBOE tickers but all VIX data appear delayed on my side which does not make sense, any support to understand what is the issue? Thanks
[2025-03-18 07:27:27]
Sierra_Chart Engineering - Posts: 24877
Tell us the exact symbol you are using for the volatility index and you will not get data for this symbol until 9:30 AM US Eastern time.
It needs to be :
VIX_CGI
[2025-03-18 07:33:24]
thanks for the answer but it does not make sense, I have been using the same symbols and receiving data feed real time without any problem until yesterday for all CBOE related indexes and especially the following: VIX_CGI, SPX_CGI, , TYX_CGI, TNX_CGI, FVX_CGI
[2025-03-18 08:01:19]
If at 9:30 AM US Eastern time today you are still getting delayed data, then :
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
Date Time Of Last Edit: 2025-03-18 08:01:47
[2025-04-27 09:36:03]
Hi, is there a way to capture or display(via a chart), daily or historical Vix Futures volumes? both delayed or real time? many thanks
[2025-04-28 16:28:20]
John - SC Support - Posts: 47903
You are able to get the VIX Futures data as part of our Delayed Streaming Data, so you can get historical data for these instruments from our data feed and display that information as you want.
If you want real-time data, then you would need to setup the "CFE" exchange. To do this, follow these instructions:
Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges*
[2025-05-01 11:48:13]
Hi, I have renewed my Nasdaq total view subscription, but = data is showing (AAPL, TSLA, MSFT, etc just to name few tickers) although I have reopened the platform several times. any reason this is happening? no change on the parameters, no change on the charts between yesterday (when it was functioning perfectly) and today. Thanks
[2025-05-01 14:07:48]
With the NASDAQ TotalView exchange you need to enter the symbols with a suffix of -NQTV (such as AAPL-NQTV).
If you do not add this suffix, then that specifies that you are wanting the data from our U.S. Equities Consolidated Tape, and since you are not setup for that exchange, you will either get the Delayed Streaming Data, or no data - depending on what service you are connected to.
[2025-05-01 14:35:28]
thanks, is there a difference between the " exchanges? I noticed a price tag difference but I don't know if that is the only difference. In a nutshell, currently I need, US equities + US 11 sectors ETF + 4 main cash ETFs (SPX, IWM, DIA, QQQ). Should I stick with NASDAQ total view or switch to U.S. Equities Consolidated Tape? thanks again for your support
[2025-05-01 17:49:26]
It depends on what you need for your data. Refer to the information at the following two links for the information on each of these exchanges:
US Stock/Equities Consolidated Tape Data Feed
Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes
There is also a third option where you have both exchanges activated and then you can get the consolidated price and volumes from the U.S. Equities Consolidated Tape with the Market Depth data from the NASDAQ TotalView. In this case, you use the suffix of _MBO to designate the symbol (such as AAPL_MBO).
[2025-05-25 18:56:28]
Hi, I am using an API to download daily gamma levels for ES, NQ, VIX, SPX. The data provider (Menthor Q) has contacted me to reflect about high level of transactions generated by Sierra Chart. The API calls for data from Menthor Q on a daily basis. Their server unfortunately records 3-4 more times data calls which is odd and their IT technical team does not see any issue on their side. Could it be a problem on my instance? many thanks
[2025-05-26 09:41:17]
This does not make sense to us. Sierra Chart has no interface to Menthor Q. So these requests are not coming from Sierra Chart.
[2025-05-26 09:54:46]
thanks and passing the answer to Menthor Q
