Date/Time: Fri, 20 Sep 2024 06:55:23 +0000
VBBR study issue
View Count: 1274
[2014-09-24 22:42:17] |
jivetrader - Posts: 408 |
please see attached issue. VBBR is not showing dashes or any useful value. chart periodicity: same result from both [5-minute] and also [Number of Trades per bar=500] thanks |
VBBR issue.png / V - Attached On 2014-09-24 22:40:31 UTC - Size: 144.17 KB - 370 views |
[2014-09-24 23:56:00] |
update: this behaviour is intermittent. most of the time i am seeing the correct value. however sometimes the study window will flash solid red/green as shown in the screenshot. in practice, it is mostly working fine.
[2014-09-25 00:15:00] |
This will be solved in the next release.
