Date/Time: Sat, 19 Apr 2025 09:45:11 +0000
Teton Routing service, Transaction fees
View Count: 116
[2025-03-18 06:44:51] |
Alexander - Posts: 16 |
Hello, I use Teton Futures Order Routing service. In addition to the brokerage commission, I pay: 1. Exchange fees, 2. NFA fees, 3. Transaction fees for Micro Nasdaq futures contracts. But Teton service has a zero cost per transaction. What settings should I check? Thank you in advance |
[2025-03-18 07:28:32] |
Sierra_Chart Engineering - Posts: 19276 |
We are not sure what you mean by what settings you should check. We do not understand the question. There is nothing in Sierra Chart you would do regarding any of those fees. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
