Date/Time: Sat, 19 Apr 2025 09:45:10 +0000
volume at parice threshold alert v2
View Count: 72
[2025-03-17 22:07:38]
sahandprs - Posts: 14
I have a problem with this Study and that is that when I try to set the stack imbalance to show only each session, it extends the previous sessions forward and mixes them with the next session. Everything is set up but this problem still exists.I set the time chart for New York from 09:30 to 12:00 and I trade during this period and I want each session to be shown separately.
Date Time Of Last Edit: 2025-03-17 23:36:23
imageScreenshot 2025-03-16 152849.png / V - Attached On 2025-03-17 23:36:07 UTC - Size: 54.11 KB - 21 views
imageScreenshot 2025-03-16 152831.png / V - Attached On 2025-03-17 23:36:11 UTC - Size: 51.14 KB - 21 views
imageScreenshot 2025-03-16 152748.png / V - Attached On 2025-03-17 23:36:15 UTC - Size: 64.46 KB - 22 views
[2025-03-17 23:38:32]
John - SC Support - Posts: 39362
You have the option to draw Extension Lines set to a value other than "None". Therefore the lines are drawn until they intersect with another bar. The ones that do not intersect will continue to display. There is no other option for this.
