Date/Time: Sat, 19 Apr 2025 09:46:40 +0000
Contract roll over
View Count: 81
[2025-03-17 21:30:01] |
User958370 - Posts: 4 |
Hi, When I did contract roll over , the previous dates were affected by the new contract so my drawings did not match the graph with new contract. Please advise how I should keep the same graphof previous dates that alrealy happened and the new contract roll over just applies to today and coming dates? Thanks |
[2025-03-18 14:21:18] |
John - SC Support - Posts: 39362 |
It sounds like you are using a "Back Adjusted" continuous contract. If you do not want the old data to move based on the new contract, then do not use a back adjusted option. Refer to the following: Continuous Futures Contract Charts: Continuous Futures Contract Rollover Options For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
