Date/Time: Tue, 15 Apr 2025 14:37:59 +0000
Dom font shrinking when I resize the window
View Count: 79
[2025-03-17 18:38:11]
c_currency - Posts: 6
I would like to reduce the size of the DOM without the fonts shrinking and the price levels condensing. How do I do this? At the moment, everything shrinks or expands when I resize. I have read the thread about auto-scaling, but the method did not work.
[2025-03-17 20:30:35]
John - SC Support - Posts: 39275
To start, there is no direct way to change the width of the Price Ladder - which is what we think you are really trying to get at. The only way to make this happen would be to change the font size of the Chart Text (which controls the price ladder text size) and make it smaller in order to get a smaller width on the price ladder.
With regards to price levels condensing, this is going to occur no matter what you do, as at some point if you are expanding the range of the data, the numbers would overlap otherwise, and the system does not allow this, so they are going to condense (consolidate) as this occurs. You can set a "Scale Increment" which the system will try to adhere to and will do as you compress the size of the range, but the opposite is not true due to what we specified above.
If you are asking something else, then we need more information. The Chart Text should never change size as you resize the window. There are some studies that do this, however.
[2025-04-04 10:57:14]
Thank you John
