Date/Time: Sat, 19 Apr 2025 15:23:45 +0000
[Programming Help] - DRAWINGS DISAPOEARED
View Count: 53
[2025-03-17 17:39:43]
User574289 - Posts: 4
HI,all my drawings disappeared from my charts , I tried to update the sierra chart version, restart the laptop but nothing.
there is a peculiar thing ,if a copy the drawings from one of my charts to my footprint they showed up ,but only on my footprint on all others charts you cannot see anything
[2025-03-17 17:39:50]
[2025-03-17 19:57:57]
John - SC Support - Posts: 39362
If you rolled over the contract, then you must not have updated the drawings to be connected to the current symbol. Refer to the following for an easy way to fix this:
Chart Menu: Update Chart Drawings to Current Symbol (Chart menu)
