Date/Time: Fri, 20 Sep 2024 06:37:12 +0000
Save DOM setup and settings?
View Count: 996
[2014-09-24 19:39:54] |
User14266 - Posts: 225 |
I would like to send my DOM setup to another instance of SC. Which file(s) do I need to transfer? Thank you.
[2014-09-25 05:02:32] |
This will be the Chartbook and also you may need to copy the Sierra3.CFG file.
