Date/Time: Fri, 25 Apr 2025 13:32:36 +0000
My past trade logs with Teton - Dorman
View Count: 484
[2025-04-02 14:14:06]
Jimmyy - Posts: 269
forgot to add - while copying my pc froze and i had to restart my pc in the middle of the copying. did i just lose all these files? because the other things which i was able to copy are working fine
[2025-04-02 15:56:31]
John - SC Support - Posts: 39480
You would just need to copy them again to be safe.
[2025-04-02 16:02:51]
Jimmyy - Posts: 269
So I wasn’t actually copying, I was moving (ctrl x -> ctrl v). The trade activity files seemed to have moved but they aren’t opening and giving me that error when i put that logs in any other installation of SC
[2025-04-02 16:24:48]
Sorry, we are bit confused by the last statement. Is that file able to be opened in another copy of Sierra Chart, or is it always showing as "corrupted"?
If it is always showing as corrupted, then you would have no choice but to delete it. You will not be able to recover the information in that file, since it was related to your Simulation account.
