Date/Time: Thu, 24 Sep 2026 23:35:21 +0000
CurrencyValuePerTick for Trade and Current Quote Symbol
View Count: 1048
| [2025-03-17 14:24:28] |
| User758025 - Posts: 5 |
In ACSIL can you access sc.CurrencyValuePerTick for the Trade and Current Quote Symbol where that differs from the Symbol as selected in Chart Settings Symbol? Thanks
| [2025-03-17 17:14:57] |
| John - SC Support - Posts: 48003 |
There is only one "Currency Value per Tick" setting. This value is used generally, although you would want to have it set appropriately for the "Trade and Current Quote Symbol" that is being used. Refer to the following: Chart Settings: Updating Currency Value per Tick for Trade Symbol If this does not answer your question, then we need more information on what exactly you are asking. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-03-21 14:48:51] |
that doesn't help at all. for others who may want to know this is how i accessed it in ACSIL s_SCPositionData PositionData; sc.GetTradePosition(PositionData); int currentPosition = PositionData.PositionQuantity; float currencyValuePerTick = sc.CurrencyValuePerTick; // Default to chart symbol value if (!sc.TradeAndCurrentQuoteSymbol.IsEmpty() && sc.IsFullRecalculation == 0 && sc.ServerConnectionState == SCS_CONNECTED) { s_SCBasicSymbolData symbolData; sc.GetBasicSymbolData(sc.TradeAndCurrentQuoteSymbol, symbolData, false); if (symbolData.TickSize > 0.0f) { currencyValuePerTick = symbolData.CurrencyValuePerTick; } else { if (sc.Index == 0) { SCString msg; msg.Format("Warning: Symbol data for %s not available yet, using chart symbol currency value per tick", sc.TradeAndCurrentQuoteSymbol.GetChars()); sc.AddMessageToLog(msg, 1); } } } |
