Date/Time: Sat, 19 Apr 2025 15:23:46 +0000
changing background colour of oscillator window
View Count: 46
[2025-03-17 09:43:14] |
SafSaf - Posts: 126 |
alright lads, is there a way of changing the background colour of just the oscillator pane in line with the direction of it's movement up or down? i want a glaring visual affect if you see what i mean. tia
[2025-03-17 16:48:26] |
John - SC Support - Posts: 39362 |
Refer to the following: Color Background Based on Alert Condition For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
