Date/Time: Mon, 21 Apr 2025 04:44:15 +0000
DRAWING disappeared
View Count: 75
[2025-03-17 07:13:17]
User574289 - Posts: 4
Hi , all my drawings from my charts disappeared , i download the new version still nothing.
There was a moment that they will showed only on my footprint because they were copied from one of my main charts, but on the main ones nothing
[2025-03-17 16:21:38]
John - SC Support - Posts: 39362
If you rolled over the contract today, then the drawings will not be there because they are associated with the old symbol. Refer to the following:
Chart Menu: Update Chart Drawings to Current Symbol (Chart menu)
If not the above, then check the "Tools >> Chart Drawing Manager" to ensure the drawings are still present on the chart and that they are not hidden.
