Date/Time: Mon, 21 Apr 2025 04:47:17 +0000
Creating a Command to Send Multiple Limits At One Time
View Count: 76
[2025-03-17 05:52:15] |
User871314 - Posts: 7 |
Is it possible to send multiple limit orders (at different prices) at a specified quantity at one time? For example, when this option is initiated, quantity of 1 placed at bid, and then another 1 limit order 2 tick below the first order, and then another 1 limit order 2 ticks below the second order. So 3 limit orders spread out 2 ticks apart but sent at the same time. Is there a way to configure the trade window to have this option or does a custom study need to be done? Thanks. |
[2025-03-17 07:39:08] |
Sierra_Chart Engineering - Posts: 19285 |
For this you would need to create a custom study to accomplish this.: Automated Trading From an Advanced Custom Study And you could use a menu command, to initiate this action: Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
