Date/Time: Mon, 21 Apr 2025 04:35:56 +0000
moving lines to new contracts...
View Count: 84
[2025-03-17 01:31:53] |
coachted - Posts: 389 |
my charts are set to volume roll...when i came in this evening none of my drawings rolled forwards...i looked for the infoin the contents and found where i needed to use the manage chart drawings window...i am a little confused shoould i switch back to marches contracts? I tried it that way using 52.25 as the roll amount with leaving the contract as the march contract...and noone of my drawings from march appeared in June.... |
[2025-03-17 15:00:30] |
John - SC Support - Posts: 39362 |
Make sure the drawings are set to be associated with the new contract symbol and that the amount you adjusted the drawings by is correct. Refer to the following: Chart Menu: Update Chart Drawings to Current Symbol (Chart menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
