Date/Time: Mon, 21 Apr 2025 04:50:13 +0000
Adjust Market Depth Data by back adjusted Amount
View Count: 102
[2025-03-17 01:30:35]
cesium - Posts: 129
Is there a way to achieve similar to adjusting chart drawings during futures rollover, to adjust market depth data for days that occured on the previous symbol?
Market Depth Historical Graph: Downloading Of Historical Market Depth Data
Thank you
[2025-03-17 14:58:06]
John - SC Support - Posts: 39362
The Market Depth data will show properly based on the adjusted data. There is no reason for anything to have to be adjusted.
Is this not what you are seeing? If there is a problem, then we need to see an image by following these instructions:
[2025-03-17 15:14:39]
cesium - Posts: 129
thank you, screenshot file should be attached
Private File
[2025-03-17 15:26:55]
cesium - Posts: 129
Added correctly the futures roll date per instructions, apologies
Date Time Of Last Edit: 2025-03-17 15:40:20
Private File
