Date/Time: Mon, 21 Apr 2025 04:47:16 +0000
Ironbeam is asking me for my account number
View Count: 106
[2025-03-16 23:26:37] |
User355317 - Posts: 12 |
Hi. Ironbeam is asking me for my account number. Where can I find it? Or is my username my account number? Thanks. |
[2025-03-17 14:54:02] |
John - SC Support - Posts: 39362 |
There is no "Account Number" in Sierra Chart, just your Account Name. If you are setting up the Teton Order Routing with Ironbeam, then they are wanting your Sierra Chart Account Name. This is used to connect your account with them to your Sierra Chart account. If you are not setting up Teton, then there is no reason for them to be asking for your "Account Number". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
