Date/Time: Mon, 21 Apr 2025 04:47:17 +0000
Server Error, Cannot connect to server.
View Count: 64
[2025-03-16 12:50:23] |
User602969 - Posts: 9 |
Hi there, I have try connecting to server and it appears my SC can't connect to the server. pls see the log attached. Windows error code: 10060. Regards, |
![]() Attachment Deleted. |
[2025-03-16 22:47:40] |
Pls help with how can i regain access to the server.
[2025-03-16 23:56:43] |
Sierra_Chart Engineering - Posts: 19285 |
Follow steps 7 through 10 here: Sierra Chart Teton Futures Order Routing: Setup Instructions Make sure the firm is set correctly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-03-16 23:58:16
